112 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Switches in a mirrored linked revit model
Wed, May 20, 2020 at 5:40:50 PM | Switches in a mirrored linked revit model
elizabethpetermathew
Hello,
I have a revit linked model that is a typical unit and linked into a main model. I have to duplicate revit linked model in the main model by mirroring it. Once I do that the electrical switches are also getting mirrored and appear in the main model in the wrong direction, see attached. Is there any way I can make it appear correctly? Thank you in advance.
Thu, May 21, 2020 at 7:15:49 AM | Switches in a mirrored linked revit model
You have mirrored a symbol and that is what will happen.  Revit is doing exactly what you have asked it to do.
I tried the process you are using a long time ago and found that is was not a good process.
Thu, May 21, 2020 at 4:38:55 PM | Switches in a mirrored linked revit model
Thank you, I will have to create a group and place individually to look correct. Wish there was a way to overide the mirror command style. Thank you.
Fri, May 22, 2020 at 7:44:21 AM | Switches in a mirrored linked revit model
You get a thumbs up from me.....That is what I found was the best process.  Remember, all groups on one level can all be copied to multiple levels as one big copy.  Then if need be, a few gorups that have to be changed on other levels can be replaced.
Model Pattern in Mirrored Groups
Fri, Apr 17, 2009 at 5:23:14 AM
Can you create mirrored walls (shiney reflective ones) with Revit?
Tue, Nov 25, 2008 at 12:07:27 PM
Curtain Panel Unexpectedly Mirrored in Project
Fri, Feb 26, 2016 at 1:22:34 PM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:29 PM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:38 AM
Page generation time: 2.3959
