Forums >> Revit Building >> Technical Support >> railing on slope won't go to exactly 3'-0" from the floor
(revit 2019.2)
For the life of me, i cannot get the railing on my sloped floor to be exacty 3'-0" to the top of the rail. its slightly off and i dont ever remeber this happening. when it hits thr top and bottom landings, its 3'-0" but its off on the sloped part. makes no sense. i tried modifying the profile, i triple checked the height of the rail, its all correct. i opened up an empty file and tried it in there as well, and still was slightly off. anyone else have this issue?
thanks!
jon
It may be an un-reported problem. Send it to Autodesk.
jsel13, Revit measures the distance vertically and that’s how you supposed to measure the rail height according to codes (at least in the US).
I'm such an idiot, you were 100% right, it was 3' straight up, problem solved! thanks for the help. i feel pretty stupid right about now!!!
Lol, don't feel bad. Brain fart happens to all of us every so often.
Cheers!
I had a big one on this .... Thanks pipj for stepping in and giving the right answer. I'm getting to be tooooo old!
Floor with Valleys and Ridges - Hosted Components Won't Slope |
Thu, Oct 28, 2010 at 2:01:37 PM
Railing material won't show up |
Wed, Jan 13, 2010 at 12:20:35 PM
'PAD' slope |
Mon, Mar 3, 2008 at 12:54:10 PM
Sloped railing on sloped floor/ramp |
Tue, Dec 9, 2008 at 9:25:01 PM
Matchlines/Splitting a floor plan |
Thu, Dec 8, 2005 at 9:48:35 PM
Members: | 2099226 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
