66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> What is pinned there? Cannot delete elevation views
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Hi all,
In the Project Browser, when I try to delete an elevation view (actually, several of them), Revit says that “Pinned objects were not deleted. Unpin them before using delete.”
The elevations have nothing hidden or pinned. View frame is unpinned. There are neither sheets nor plan views in the projects. The elevations do not have any callouts or sections, or any annotations.
I have posted this question long time ago, but then it was a plan view. Now I have the same problem with multiple elevations. Maybe someone have had this problem before? (Revit 2020)
The problem is solved but not understood.
As I said, there were no plan views in the project. I created a couple plan views, found these elevations and sections which i could not delete from the Project Browser. They were NOT PINNED. I simply deleted them from plan views.
But how com I easily deleted other tens of sections and elevations from the PROJECT BROWSER but not these which i deleted from plans?
I will appreciate any ideas. Thanks.
Pinned walls in 2014 can't UnPIN Walls |
Wed, Oct 15, 2014 at 3:33:17 PM
any work around for this? transparent glass in shaded elevation views, revit 201 |
Mon, Jan 28, 2013 at 11:19:53 PM
How to delete unused views |
Fri, Jan 26, 2018 at 1:19:17 PM
Multi-view Elevation - Reference SIM |
Fri, Mar 9, 2012 at 8:40:42 AM
Managing Pinned Files for a Team |
Tue, Aug 5, 2014 at 9:50:28 PM
Members: | 2016890 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
