33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Nested Link in nested link workset control?
Thu, Feb 27, 2020 at 5:39:38 PM | Nested Link in nested link workset control?
NobleLP
I have a linked stair inside of a project unit file that in turen is linked to a larger hotel file (this is a large hotel project)
I have created variations the the stair on different worksets.
I the loades unit should show the workset state of the nested stair (closed or open etc.) this is true on the initial load of the unit file. However If I modify the worksets int the unit and save the unit file, then reload the unit int the hotel file the worksets seem to be "stuck" with the initial load state.
question:
is there a way to "clear" the workset and have the setting in the nested file become curent state?
PS
Removing the link and relinking isnt a good soulition since there are so many instances of the unit.
Fri, Feb 28, 2020 at 5:19:25 AM | Nested Link in nested link workset control?
I don't really understand what you are doing or why.  Seems that you have just made yourself a lot of problems.  The stair should be in your project file.  If you want different variations, learn to use design options.
Famillies - Cannot link nested file parameters to host
Fri, Jan 11, 2013 at 9:55:45 AM
Visibility in Nested (Attached) Linked Models
Mon, Nov 4, 2013 at 2:44:30 AM
Hide a workset in a link
Sat, Sep 20, 2008 at 10:04:46 AM
? regarding controlling visiblity within linked files according to Worksets
Fri, Jul 2, 2010 at 10:01:41 AM
Nested family: no option to choose the little button
Mon, Jul 27, 2015 at 9:11:38 PM
Page generation time: 0.4542
