80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Add angle parameter to generic annotation with offset parameter
Thu, Feb 27, 2020 at 6:40:24 AM | Add angle parameter to generic annotation with offset parameter
baggins79
Hi guys,
Please find attached. I don't know how to lock reference line with angle parameter to symbol. I guess horizontal and vertical offsets are constraining it somehow. I know it should be possible as per attached 'good family' file, which is working.
Fri, Feb 28, 2020 at 12:52:31 PM | Add angle parameter to generic annotation with offset parameter
marmiketin1
4.5 Stars: 10 Votes
The best way to have a rotation parameter in any family is to create a family that contains whatever it is you want to be abel to rotate and then nest that into a host family that contains the reference line that will rotate the using a parameter. Then you can align the 2 origin lines of the nested family to the reference line and its end point. The only reason the good family is working is because the lines are so short and close together that revit guesses that it is all related and rotates all the lines. This is not good practice however.
Mon, Mar 2, 2020 at 12:57:06 AM | Add angle parameter to generic annotation with offset parameter
baggins79
Thank you,
will try out
Generic Annotation with Family Category based parameter
Mon, Sep 16, 2013 at 7:18:15 PM
Angle Parameter moves objects?
Fri, Jul 22, 2011 at 9:13:20 AM
Angle Parameter in family
Mon, Oct 12, 2020 at 7:55:09 AM
angle parameter for symbol won't work my way:)
Thu, Nov 1, 2007 at 6:18:52 PM
3D Swing parameter!! Help!!
Sat, May 11, 2013 at 7:03:34 AM
Page generation time: 1.4320
