77 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> roof structure
5 Posts No Rating |
hi well i'm a new user of revit but i am used to the most common commands but regarding structure i would like you to tell me how to draw tirantes (word in spanish i dont know how it is in english....its wood under the roof...) ihave tried but i cant draw anything wich is not just vertical or horizontal....
Another thing is how can i draw the thing (another unknow word) which goes at the top of the roof over the tail where two roof joins...in spanis it's called cumbrera.
Thanks for this space and i must say that this page is very good... well bye an apologises for my english jajaja.:-)
not much help for you, but for anyone searching this thread, I believe "tirantes" means a roof brace,
atleast according to spanish/english dictionary.
"cumbrera" didn't have a translation
couple of ways you could do this.
1. go to a side elevation, draw a new work plane on the angle that you require, then model your brace on this new work plane in the appropriate plan.
2. use create,structural framing,solid extrude,solid blend
hope this helps
Macca Sunshine Coast QLD Australia |
how to dreate a double gable ended roof on a square structure???? [ 1 2 ] |
Fri, Mar 13, 2009 at 7:42:49 PM
25
Additional Roof will not attach to original roof |
Fri, Jun 7, 2013 at 7:56:40 AM
Sloping Roof Structure |
Mon, Dec 17, 2007 at 7:05:09 AM
adding crickets to a sloped roof structure |
Mon, Oct 16, 2017 at 9:28:29 AM
Sloping 5/14" metal deck roof to sit on sloping OWSJ structure |
Wed, Dec 3, 2014 at 8:50:16 AM
Members: | 2022512 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
