67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> parameter for family type count (2019)
Wed, Jan 15, 2020 at 8:50:46 AM | parameter for family type count (2019)
ledgewood33
i have a window tag that is a type parameter and i would like to include another parameter that shows the total count of that family type in the project. i am not sure what the category parameter i should create to add to this tag so that i will see the the window type designation letter and the count of that window type in the model.
Wed, Jan 15, 2020 at 10:25:00 AM | parameter for family type count (2019)
I don't see anyway to do this in a family with native Revit.  Obviously, you can do it with schedules but that would not be assigned to a parameter.
Maybe you could do it with Dynamo but you would probably have to run the Dynamo program everytime you needed to update this parameter.
Wed, Jan 15, 2020 at 3:37:25 PM | parameter for family type count (2019)
CDWdavid
5 Stars: 5 Votes
Please see the attached pictures. Don’t know if that’s what you are looking for.
On attached schedule, for Door Type A1, and M, you will have the counts. However the Door Mark would not be shown for the obvious reason.
In Schedule Properties, under Sorting/Grouping, select sort by “Type”, and un-check “Itemize every instance”.
Add the “Count” field.in your window schedule.
You can try to create your window family shared parameters and play with it. Hope you can get what you want.
Schedule Count Parameter
Wed, Sep 2, 2009 at 11:02:11 AM
COUNT Parameter in formulas: a workaround
Thu, Apr 10, 2014 at 6:40:33 AM
excluding a type in the family type parameter
Thu, Mar 20, 2008 at 3:38:33 AM
Family-Type Parameter deleted
Mon, Jun 3, 2013 at 5:04:19 PM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ]
Tue, Aug 27, 2013 at 3:53:54 AM
29
Page generation time: 1.1467
