Forums >> Revit Building >> Technical Support >> Can't unpin a view
Hi all,
please help me to unpin a plan view. Revit 1018, no worksets, no design options, nothing.
When select a plan view in the browser, get a message that I should unpin the elements first.
The instance ID is that of the view.
The viewframe is selectable and not pinned.
Thanks
Do the unpin from the sheet where the view is locked in place.
This view is not on sheets. I checked them all.
Do you have "Select Pinned Elements" turned off?
I can select pinned elements. I ve selected all what possible and unpinned.
Something is wrong with the file or the view so just recreate it.
I've made a view based on the same level. It works well. You are right, the old view is probably corrupted. I cannot figure out what is "PINNED". But the project is big and I need to delete all what's possible.
Thank you again
Pinned walls in 2014 can't UnPIN Walls |
Wed, Oct 15, 2014 at 3:33:18 PM
Beam system, cant offset? |
Fri, Feb 13, 2009 at 8:16:04 AM
Problem with 'Coarse' & 'Fine' view options |
Thu, May 16, 2013 at 2:07:41 AM
'Activate View' on sheets |
Tue, May 7, 2013 at 11:26:57 AM
how are joined beams and floors in 3d view? |
Mon, Jun 27, 2005 at 6:54:41 AM
Members: | 2099075 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
