86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
Fri, Nov 15, 2019 at 3:54:01 AM | Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
giovanni22
I usually insert dwg files in my projects in order to make area calculations on them.
The problem is that I dont want to see the dwg file through the color, and  to see it only where there isn't area calculation. Is there a way to make the color opaque?
Because of this problem I used on my last projekt ''Filled region'' but then I hadn't the possibility to use tags for the calculation of m2.
Is there a solution to this problem?
Thank you.
Thu, Nov 21, 2019 at 3:00:34 AM | Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
giovanni22
Many must use dwg files for the area calculations.
How you solve this kind of problem?
Thu, Nov 21, 2019 at 2:13:48 PM | Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
3.5 Stars: 395 Votes
I don't understand your question because I can't see how you would make an area calculation from the CAD file that you can't make from the Revit.
Whenever I have a linked dwg or linked revit, it is always in a workset that can be turned off.
When you insert a CAD file, you can control the colors.
Fri, Nov 22, 2019 at 12:27:55 PM | Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
giovanni22
Hi!
Maybe I didn't explained well the problem.
First I link or import a dwg file on an "area plan" of my project.
Then on top of the lines of this dwg file I make "area boundaries" in order to calculate the area of a part of the dwg file.
I would like to be able NOT to see the lines of the  dwg file that exist bellow the color of the area that I want to calculate, but To See all the the rest of the dwg file outside of this area.
I I hope that I have explained this more clearly now.
Thank you for the interest at my problem.
When I make an ''Area plan'' not all the original elements show up.
Thu, Aug 15, 2019 at 8:17:46 AM
2'x2' fluorescent fixture on rcp covers up part of adjacent 2'x2' return fixture
Fri, Aug 28, 2009 at 1:06:16 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
Wed, Aug 19, 2020 at 7:59:03 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Page generation time: 4.9333
