80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> I can't connect more than one VAV system to an Air Handling Unit
Tue, Oct 15, 2019 at 4:08:07 PM | I can't connect more than one VAV system to an Air Handling Unit
jeeenyuss
The subject is pretty much the problem.  I have been assigned the task of getting the systems in a project in order. All of these systems from diffuser to the VAV have CFM being calculated.  Once they reach the VAV, the CFM flow drops to 0, and then the 0 CFM flow continues all the way through the remainder of the ducts back to the AHU.
I spoke with one of our more senior Revit users, who suggested that the VAVs must be assigned to the AHU.  He hasn't done any Revit mechanical work in a few years, so he couldn't help me beyond that.  Unfortunately, there is nobody else for me to ask about this.  Hopefully someone here can help.
There are currently 74 separate VAVs within this project.  I need to assign the VAVs to one of two separate air handling units.  I can assign one of them to one air handling unit, but if I assign a second one to that air handling unit, the first one is no longer connected.  What am I doing wrong, or what is the solution here?  I've never had to do this and I'm having a lot of problems finding help.
Thanks in advance to whomever can help!
Multi-Zoned Air Handling Unit (AHU)
Mon, Jan 18, 2010 at 3:07:11 PM
HVAC Systems
Wed, Sep 16, 2009 at 7:03:09 AM
Deleting an air termainal doesn't update CFM
Thu, Jul 19, 2012 at 10:35:57 AM
REVIT MEP - Outside Air
Thu, Apr 24, 2008 at 11:57:56 AM
Airhandling system.
Thu, Mar 6, 2014 at 1:03:14 PM
Page generation time: 1.4666
