62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimension Text Spacing
Thu, Sep 26, 2019 at 5:21:35 AM | Dimension Text Spacing
GLKIRK
Hi,
I have read alot about here text, but still I have a concern or two.
I see in other designers text that the space between the number and the dash is tighter  than anything I can create Any thoughts?
I have "stylusBT" in a a drafting view in my template file, but cant seem to load it into the project. Any thoughts?
Thanks!
Thu, Sep 26, 2019 at 7:14:17 AM | GLKIRK
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting GLKIRK from 2019-09-26 05:21:35
In dimension type properties -> units format -> check suppress spaces,
or globally under project units -> length -> check suppress spaces.
Thu, Sep 26, 2019 at 7:42:16 AM | Dimension Text Spacing
GLKIRK
Thanks, I couldnt get much sucess in the properties but when I went to Manage-Length, I got good sucess.
Thanks again
Thu, Sep 26, 2019 at 7:50:05 AM | GLKIRK
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting GLKIRK from 2019-09-26 07:42:16
Uncheck 'use project settings' if 'suppress spaces' is grayed out.
Edited on: Thu, Sep 26, 2019 at 7:51:23 AM
Thu, Sep 26, 2019 at 9:05:10 AM | Dimension Text Spacing
GLKIRK
Yes, I see that now.
Thanks, another great learning expeeience!
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Text line height spacing - can it be changed like the width?
Thu, Dec 12, 2019 at 4:29:09 AM
Stacked Dimension Text (Prefix/Suffix)
Fri, Jan 27, 2006 at 6:21:26 AM
Help! Need control of schedule row spacing.
Wed, Jun 15, 2011 at 12:26:11 PM
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Page generation time: 0.4809
