84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> VISIBILITY OF LEVELS
Wed, Jun 7, 2006 at 1:37:35 PM | VISIBILITY OF LEVELS
mezdez24
5 Stars: 2 Votes
I have 2 separate buildings, each with their own levels. Since I have these different levels, i have level lines showing up in my sections that I don't want to see. Is it possible to turn them off somehow? HOpefully this is clear enough to answer.Thanks in advance!
Wed, Jun 7, 2006 at 2:43:39 PM | RE: VISIBILITY OF LEVELS
ICON
5 Stars: 3 Votes
i wonder if you can hover over the offending level line and the "hide annotation" in drop down menu
Wed, Jun 7, 2006 at 2:59:17 PM | RE: VISIBILITY OF LEVELS
mezdez24
5 Stars: 2 Votes
THANKS ICON! I never knew that option was available! I always just clicked on the object or thing that i wanted to adjust. I'll keep that in mind in the future! Thanks again!
Thu, Mar 19, 2009 at 1:00:35 PM | VISIBILITY OF LEVELS
ahocutt
You can also adjust the levels in elevation view to just extend around the particular building so you will never have to hide them (or forget to hide them)
Fri, Apr 17, 2009 at 5:51:38 PM | VISIBILITY OF LEVELS
fixybopixy
does anyone know why my level lines dont appear in section? I have them turned on in visibility/graphics but i still dont see them.
thanks
rebecca
Tue, Jul 13, 2010 at 12:45:49 PM | VISIBILITY OF LEVELS
mezdez24
5 Stars: 2 Votes
Rebecca-
Check to see if they are temporarily hidden. In 2010, at the bottom of the screen in the same toolbar as the scale of the drawing, theres a light bulb icon which is the 'reveal hidden elements'.
 Hope that helps if you haven't figured it out already.
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
VISIBILITY PROBLEMS
Wed, May 2, 2007 at 3:31:32 AM
SCOPE BOX VISIBILITY MESS
Wed, Apr 13, 2016 at 3:37:15 PM
gridlines not appearing on upper levels
Mon, Oct 27, 2008 at 3:20:58 PM
Revit 2013- negative levels wont allow me to place columns
Tue, Oct 9, 2012 at 6:52:59 PM
Page generation time: 0.4482
