50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Plan Cut Plane on stepped condos
2 Posts No Rating |
I have Condos that march down a sloped site (20" grade difference between each) Is there a trick to get an overall plan to show a consistant cut plane?
Please explain your question furthur.
You do understand plan regions?
2 Posts No Rating |
If I have a series of condos stepping down a site and my plan view range cut plane is at 4'-0", each plan is going to look different and you may end up cutting through a different floor all together.
Use plan regions to redefine your cut plane.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-594B7B97-0D59-4B03-9544-E403BD03BE48
Generic model cut plane & plan regions |
Thu, May 20, 2010 at 6:44:22 AM
Stepped Roof with Overhand |
Fri, Oct 25, 2013 at 10:40:43 AM
Cut plane for doors and widows different from plan!! |
Wed, Oct 18, 2006 at 8:41:37 AM
window does not get cut in plan view. |
Tue, Jul 12, 2011 at 10:37:20 AM
Cut plane problems with Families - Revit 2013 |
Tue, May 21, 2013 at 2:29:27 PM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
