92 Users Online (91 Members):
Forums >> Revit Building >> Technical Support >> Window elevations
i have a long run of storefront that is curved, but not a true curve. the window panels are actually placed at shallow angles so small that they appear to be a curved unit. my question is i need to make a window elevation and dim and note but the elevation shows the storefront as it would look if you see it. which is fine. but how can i do the elevation to show the real size of the windows, ie "flatten it" so to speak, so they can be correctly sized? any ideas or suggestions would be great. i know i cant tbe the first one to come accross this matter.
thanks for any help
Whenever I had this situation, on my window sheet, I included a plan view that only showed the storefront. Then I used dimensions that where center to center of the mullion glass intersection. Typicall I had an arc centerline at that point and I used a chord dimension.
thanks, that is what is was leaning towards. just wanted to see if i was not alone. thanks again
What are people using window elevations? |
Thu, Jan 31, 2008 at 9:44:56 AM
how to add elevations to door & window schedules |
Tue, Oct 30, 2007 at 11:59:24 AM
Window Elevations |
Fri, May 18, 2007 at 5:18:02 PM
To Window Tag or not to Window Tag...? |
Thu, May 21, 2009 at 12:33:24 PM
window sills |
Sun, Jun 18, 2006 at 5:16:17 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
