22 Users Online (21 Members):
Forums >> Revit Structure >> Technical Support >> Newbie Questions
0 Posts No Rating |
I have searched all over and can't find answers to these particular questions, at least that I have found so far.
1.) Selection by Rule Set? I want to only select members that "begin with" HSS, but there doesn't seem to be a way to get this. Basically I want to create a Rule and use it to select a lot of members at once, anyway to do this?
2.) Partial Beam Profile on Plan? When doing a Structrual Framing Plan, you can do Coarse which is just lines or you can do Medium which will show you the outline of the beam.
Is there a setting that will show you the line you get in Coarse but with a small section of the beam showing it's profile like you get with Medium?
Other programs allow you to show "partial profile", only 2 or 3 feet of the member is the Medium style while the rest of the beam is just the line.
3.) What is the AISC 14.1 folder for? If we use the families in that folder the weights will not show up on the schedule. Just wondering what the folder is for and if it really matters if you use it or not. Using the families located where the 14.1 folder is stored does show the weights.
Thanks
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
- Sorry - Revit does not do well with strings
- Not available in Revit
- https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=2ahUKEwjZv96whZfjAhUImuAKHcyYBncQFjAHegQIABAC&url=https%3A%2F%2Fwww.cadlinecommunity.co.uk%2Fhc%2Fen-us%2Farticle_attachments%2F200680672%2FScheduling_Steel_Weight_in_Autodesk_Revit_2015_.pdf&usg=AOvVaw0dnCDwi2iLY0DAvaHIg5b6
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
2. Could be done using Dynamo.
Multiple Newbie Questions |
Mon, Sep 23, 2013 at 8:47:23 AM
yet another revit newbie....with alot of questions |
Mon, Jan 14, 2013 at 8:08:21 AM
newbie here, questions. |
Sun, Jan 18, 2009 at 10:14:42 AM
Complete Newbie Questions |
Wed, Jun 20, 2012 at 2:39:58 PM
hello newbie here and questions about rendering |
Fri, Jul 30, 2010 at 3:47:38 PM
Members: | 2025990 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
