36 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> Hardware >> Revit running extremely Slow/Lagging
Mon, Jun 17, 2019 at 6:32:57 AM | Revit running extremely Slow/Lagging
SLIPPS
I have a high spec laptop that I use as my daily workhorse asa MEP Draftsman, but despite it having
(NVIDIA GeForce GTX 1060 6GB GDDR5 graphic card,
i7-6700K CPU 4 Core 4.0GHz up to 4.2GHz 8MB Cache
RAM - up to 4 slots , 64GB DDR4 2400Mhz RAM
525GB Crucial MX300 M.2 SSD SATA - 530/510MBs
1TB 7200 rpm hard disk drive)
It 'REALLY' lags when I use Revit...when I say lags I'm talking 5-8 minutes at it's worst, of the dreaded blue wheel,,, when I check its performance in the task manager (screen shot attached) my CPU is at 6% my graphics card is at 3% everything else is around the same but wifi and ethernet are maxing out,,,,Oh I mostly model on BIM360 Design (Cloud) over wifi but even when I'm plugged into a network cable it does really behave any better. It even took 3 hours to just install (not download) a newer version of Revit the other day. I regularly clean up the laptop and run premium a antivirus program almost weekly to make sure its not those issues. It's 3 years old but it has always lagged...its really annoying,,,anyway I wanted to ask if any you have had similiar issues? or if can recommend anyone who can do a remote analysis on it? everyone technical I talk to doesnt understand the first thing about Revit's demand on computers so I'm at a loss. I don't mind upgrading but it just seems this machine just isnt working hard for all the output troubles I'm having?? Any feedback would be greatly appriciated
Thanks in advance
Simon Gray
Mon, Jun 17, 2019 at 7:50:25 AM | Revit running extremely Slow/Lagging
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
PC is fine. Maybe it is your model. Are you managing it efficiently?
Run through my article as it lists some model management actions to take to speed things up.https://www.linkedin.com/pulse/rapidfire-revit-morrow-brady/
Wed, Jun 19, 2019 at 11:18:35 AM | Revit running extremely Slow/Lagging
SLIPPS
Beaucoupnice, no the model I work on are the same as the other guys with similiar machines and they dont have this issue, so I can safely rule that out
Slipps
Thu, Jun 20, 2019 at 6:51:35 AM | Revit running extremely Slow/Lagging
Your last post is the key to your question.   "...the other guys with similiar machines and they dont have this issue...".  Similar is not same.  Something with your machine, your setup or your personal use is the problem.
Thu, Jun 20, 2019 at 1:18:58 PM | Revit running extremely Slow/Lagging
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
If your model is very well managed and is running as efficiently as can be then here's some other thoughts. Have you tried turning Revit's hardware acceleration on if its off or off if its on? Are all your drivers and Revit up to date? Is your computer specs exactly the same as everyone elses? BIM360 with big models will be slow - although it does depend on the model size. How big is the model? Do you have a local file on your PC ( i.e. ar you working collaboratively). Try deleting it and creating a new one. Try detaching the central file, its temp and backup files and creating a new central file. Do you have any files linked in - can they be removed? Don't work on wifi - its too slow. If still slow while hardwired, try replacing network cable. Update windows.
Topo Surface Edits Running EXTREMELY SLOW in 2010. Help :)
Mon, Jan 18, 2010 at 8:39:00 AM
Revit Architecture 2013 extremely slow in 3d Realistic View ambient and sunlight
Fri, Mar 8, 2013 at 8:36:49 PM
Revit running slow on my computer
Mon, Jan 25, 2010 at 6:42:56 PM
revit running slow
Mon, Feb 15, 2010 at 2:40:53 AM
Revit 2013 Running Slow
Fri, Nov 8, 2013 at 9:19:27 PM
Page generation time: 1.6907
