158 Users Online (157 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Offset of the Wall foundation from the wall in Height
Sat, May 11, 2019 at 6:13:43 AM | Offset of the Wall foundation from the wall in Height
emimari
Hi,
I'm aiming to get a quite accurate BIM model so I wanted to make water isolation as a One Layer Floor. But now the foundation wall cuts it and that's not how it should be presented. I wanted to offset the wall from the foundation in its height but that's not possible. Have any of you encountered such a problem and solved it? Maybe you have some other workflow with which I could implement that?
Regards,
Emilia
Sat, May 11, 2019 at 7:17:44 AM | Offset of the Wall foundation from the wall in Height
I don't see what you are talking about.
If you mean you need to see a heavy line under the wall, you will have to modify this.
Sat, May 11, 2019 at 12:48:55 PM | Offset of the Wall foundation from the wall in Height
emimari
The heavy live is a floor with 0,5 cm thickness and I can't see a way to serepate the wall from the wall foundation
Sat, May 11, 2019 at 4:11:18 PM | Offset of the Wall foundation from the wall in Height
The wall does not cut this.  It is joined and therfore each edge line is a thinner line.
Sat, May 11, 2019 at 7:17:16 PM | Offset of the Wall foundation from the wall in Height
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I think you’re over modeling this detail. I’d show the waterstop in section view only, as a detail element. The footing (structural foundation object) is attached to the wall and it cannot be separated.
If you really need to model it, use a basic wall for your footing instead of structural foundation wall. Apply a sweep as your waterstop membrane on top of the wall – see picture.
Pozdrawiam!
Sun, May 12, 2019 at 5:14:13 AM | Offset of the Wall foundation from the wall in Height
emimari
Yeah, I agree that I may be overmodeling but on the other hand I want to have a quite precise model for the material takeoff. Modeling it as the wall sweep could be the solution because I will see that in the schedule but on the other hand I loose the information about structural element of the footing (modelling it as a wall when it's not) and I multiply the number of walls in the project. What's you usual workflow for this element?
Sun, May 12, 2019 at 9:59:10 AM | Offset of the Wall foundation from the wall in Height
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Apply the sweep to the bottom of your foundation wall then - not to the footing.
I always address it as a detail element in section view, but I do not do material takeoffs.
By the way, if you join your floor (waterstop) with the foundation wall, it will cut the wall, so I think you will get a detail that you're after.
Sun, May 12, 2019 at 2:43:12 PM | Offset of the Wall foundation from the wall in Height
emimari
I was doing the waterproof layer as Finish 1 Function, so that's why the wall was cutting it. Now I've changed it to Structure and it doesn't anymore. The floor doesn't have structural function turned on so it should be fine as the Construction Team won't see it as atructural element. Thanks for your help because it made me check this optionSmile
Pozdrawiam Smile
Sun, May 12, 2019 at 2:43:16 PM | Offset of the Wall foundation from the wall in Height
emimari
Pozdrawiam Smile
WALL FOUNDATION CORNER
Tue, May 5, 2015 at 10:17:13 AM
Stepping foundation wall to follow grade
Fri, Nov 9, 2007 at 1:57:54 PM
ICF and wall aligment
Sat, Oct 8, 2016 at 11:55:36 AM
splitting full height wall sections
Wed, Jul 28, 2010 at 2:13:16 PM
Placing Ext wall on foundation wall
Thu, Sep 1, 2011 at 11:17:57 AM
Page generation time: 1.6147
