76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> Disappearing point cloud Revit 2018
We are currently working on decent size project too and were experiencing some visibly issues. Revir 2018
We have several point clouds loaded in the project (basem, ground, etc) and on each level we have visible only relevant pointclouds (basement on basement level). However, when changing views e.g. floor plan <-> section <->other floor plan the pointclouds sometimes disappear from the all views. The links are still present and loaded, their visibility settings are still on and point cloud is nowhere to be seen.
If we simply reload the link nothing happens, we have to remove the link and bring it in again. This all would be fine if the reloaded cloud came to correct place! There is a visible shift. We checked the coordinates of the model/pointcloud in Revit vs recap and we clearly see the cloud is in incorrect place.
All clouds are loaded same way as at the beginning of the project (shared coordinates)
Thanks for your suggestions
Point clouds are memory intensive. I would only use them with each in its own workset so the workset was normally unloaded except when needed. Having it off in VG doesn't work the same.
Thanks for your suggetsion. Look like I will have to find out more about worksets because we dont use them (we didnt have any need for it yet)
Point Cloud in Revit 2014 no longer working in Revit 2015 |
Fri, May 15, 2015 at 3:23:06 AM
Revit 2014 Point Cloud Plot Issue |
Fri, Apr 25, 2014 at 8:44:48 AM
Export the Point cloud file to Auto CAD with Revit |
Wed, Apr 2, 2014 at 4:38:32 PM
Point Cloud location |
Tue, Apr 8, 2014 at 2:23:56 PM
Revit 2014 Point Cloud Benefits/limitations? |
Fri, May 24, 2013 at 8:00:13 AM
Members: | 2022369 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
