77 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> window schedule - skylights
![1 Stars: 1 Votes](/images/stars_1.gif) |
my skylights and roof hatches are scheduling and i dont want them to be. is there a toggle somewhere that i can make them not schedule?
worse comes to worse, i can put a blank filled region over them, as they are the last two rows on my schedule, but it would be easier if i could just omit them from the schedule.
thanks,
GD
i am still an idiot...is there a way to fix this that i am missing?
Post edited on 2006-06-06 18:50:33
![4 Stars: 4 Votes](/images/stars_4.gif) |
Go into your filters on your schedule and set the numbers to only show up to last true window then the rooflights will not appear on the schedule
![5 Stars: 3 Votes](/images/stars_5.gif) |
any hints as to forethought that might go into filtering. Seems like a powerful asset, do you just create filters as you go or are there some "standard filters" that I guy could tap into??
![latemore Avatar](user_avatar/6368.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
a little trick i stumbled on -
for items you do not want tagged, give them a mark, eg z1.1, instead of w1.1, and filter your schedule to only show 'w'. i sometimes use window/door openings but no actual joinery, and call them z something. same thing could work on skylights.
Thank you for the suggestions.
LOOKING THROUGH THE WINDOW, SCHEDULE |
Sun, Dec 19, 2004 at 7:03:39 PM
Skylights not associating with room |
Sat, Dec 11, 2010 at 1:18:26 AM
Window's dimension don't show up in the window schedule |
Fri, Aug 17, 2012 at 1:34:43 PM
Adding skylights and slopes to a roof |
Thu, Jul 12, 2012 at 8:33:07 AM
door in window schedule |
Thu, Apr 29, 2010 at 7:47:41 AM
Members: | 2016928 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
