Forums >> Revit Systems >> Technical Support >> Using Tab to select Families in Families
Thu, Mar 28, 2019 at 3:58:28 PM | Using Tab to select Families in Families
cboersen
Revit 2018, OS 10
I made a shower using a Bobrick grab bar and a Bobrick seat.  Once place on a sheet I can tab into the shower family and select the grab bar, but not the seat.  The two families look like they have more or less the same settings.  Any ideas why I can select one, but not the other?
Fri, Mar 29, 2019 at 4:34:49 AM | Using Tab to select Families in Families
From your HELP:
  • If you nest a family that is not shared, components created by the nested family act with the rest of the element as a single unit. You cannot select (edit), tag, or schedule the components separately.
  • If you nest a shared family, you can select, tag, and schedule the components separately.
Using families from Steel Select.com
Thu, Jun 19, 2008 at 7:15:33 AM
Revit metric families
Mon, Apr 15, 2013 at 8:37:31 AM
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
How can a get a parts count for a set of families?
Tue, May 20, 2008 at 6:59:12 AM
Revit Families
Fri, May 24, 2013 at 4:23:33 PM
12
Page generation time: 1.1926
