46 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Area Schedules and Area Schemes - Revit 2019
![iamian33 Avatar](user_avatar/135203.jpg)
148 Posts No Rating |
Greeetings.
I have a few different area schemes and a few different area schedules ... how can I identify which area scheme is associated with a particular area schedule?
The 2nd question: can an area schedule be associated with a different area scheme? I suspect that the answer to this is "No" but I hope I am wrong.
It is my hope to avoid (re)creating similar schedules for each scheme, but again, I suspect I will need to do just that.
Thanks, in advance, for your input.Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
![4 Stars: 19 Votes](/images/stars_4.gif) |
Question 1: You will see the Area Scheme in the view properties, as shown in the image.
Question 2: You cannot change the scheme for an area schedule, as that is what it is based on when it was created. But once you have it set up, you can create a view template from that and use it for schedules generated from a different area scheme, so that you don't have to do all the setting up again.
area plans & schedules help |
Thu, Oct 8, 2009 at 12:56:31 PM
2 different Area Schedules on same project |
Fri, Aug 4, 2017 at 12:41:21 PM
Combining Room Schedules and Area Schedules into one Large Schedule |
Thu, Jan 3, 2013 at 10:57:33 AM
area color schemes |
Fri, Jan 27, 2012 at 2:36:28 PM
Area Schedules showing Metric and Imperial |
Thu, May 28, 2009 at 11:49:29 AM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
