61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Life Safety Plan Travel Distances?
Tue, Jun 6, 2006 at 3:29:58 PM | Life Safety Plan Travel Distances?
CSTANLEY
I'm curious about what ways anyone has been able to draw life safety travel distances, and then be able to schedule the distances. for example: i've experimented, as a workaround, using a property line to sketch my travel paths, but if it's not a closed loop, i can't schedule the distances. i'd like to have my schedule display as a table of distances from numerous travel paths. lines would be my preference, but they can't be scheduled. in ACAD it would be a polyline, with a total distance displayed. any ideas? how does everyone else do it?
Tue, Jun 6, 2006 at 3:43:26 PM | RE: Life Safety Plan Travel Distances?
quiller
quiller Avatar
2.5 Stars: 3 Votes
Here's a way......workabound #1001!!! Use the railing tool and draw a railing from the door to the end of the hallway. Then create a schedule and pull in the lenght field and thats it. It's not nice, but it works!
Tue, Apr 24, 2007 at 2:29:47 PM | Life Safety Plan Travel Distances?
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
People have joked at work that I would build my whole building as a railing system if they'd let me. I like that idea, but it won't work in my case because we put the length as text at the starting point of each exit path. I think I'm out of luck making a family that calculates the length automatically and labels the end. I would need some sort of sweep/annotation hybrid template. Noticing the "Chain" check box on the distance options makes figuring the distance "manually" a lot more bearable though.
Life Safety Paths
Fri, Oct 4, 2019 at 4:35:29 PM
Life Safety Plans
Thu, May 22, 2014 at 9:16:09 AM
Detailed Life Safety Symbols
Mon, Jan 3, 2022 at 2:48:32 PM
Calculated Values in Room Tags
Fri, Feb 8, 2008 at 2:58:39 PM
Exit Sign Issues
Wed, Feb 8, 2012 at 1:17:31 PM
Page generation time: 0.6113
