54 Users Online (53 Members):
Forums >> General Discussion >> Revit Project Management >> Illustrator to Revit
Our office updated our logo and we are revampling everything with our drawings. Even though I told them it isn't possible to create text that distributes to a fixed width, they insisted on using this formatting on a few pieces of text in our titleblock.
I created the text in illustrator, created outlines of the text, and exported it as a .dwg. It looks fine in autocad, but suprise suprise it breaks when imported into revit. Aparently some of the letters contain splines and that is what breaks down in revit.
I know importing CAD text into revit is a bad idea. But I need a solution to make this work somehow.
I've even tried using a jpg of the areas of text that break, and they look super fuzzy when you print, even though they are a 1-1 on the size.
Why not make an image of this and insert that?
That is what I did, but there is artifacting that happens when you print the part of the title block that is an image. Is there any other solution?
I have never had artifacting problems using an image in a titleblock. Something in your process needs to be changed.
you could try to import your stuff in a detail Family and then upload it in your Sheets
Export to Illustrator file |
Mon, Nov 14, 2016 at 10:43:15 AM
Laptop for 2012 Revit Architecture-Illustrator-Photoshop |
Mon, Feb 11, 2013 at 1:41:31 PM
Revit modeling services provided [ 1 2 ] |
Sat, Jun 27, 2009 at 3:13:55 AM
16
Looking for Revit 2013 subcontract draftsman |
Sun, Jan 5, 2014 at 5:37:40 PM
Best new laptop 2015 for Revit |
Fri, Jul 10, 2015 at 11:11:35 AM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
