56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> sheet __ of 20
Wed, Feb 20, 2019 at 4:17:35 PM | sheet __ of 20
aaronkennedy
How do I create the sheet page number on a sheet.  the sheet    of 20 is easy but I cant figure out how to create a lable that will sync with my sheet order on my index.
Thanks,
AAron
Thu, Feb 21, 2019 at 6:41:39 AM | sheet __ of 20
Your question is not clear.
Thu, Feb 21, 2019 at 8:09:59 AM | sheet __ of 20
aaronkennedy
Sorry,
I want to have a label on a sheet that says this sheet is "1 of 40 sheets" for the cover sheet 30 of 40 sheets" for the 30th sheet in the set, so on..  I would also call it page numbering.
I want it to self propogate so I do not have to go change numbers.  i want to edit the title block as to the number of sheets then have the sheet order / page number automatically fill itself in.  Maybe from my drawing index?
I hope this helps.
Thu, Feb 21, 2019 at 5:29:33 PM | sheet __ of 20
Sorry - not going to happen.  You want it backwards but Revit reads the drawing list from the sheet.
Fri, Feb 22, 2019 at 8:52:57 AM | sheet __ of 20
aaronkennedy
I guess I will have to try it in adobe. Thanks for taking time to respond.
Links to each sheet in sheet index
Sun, Aug 21, 2016 at 11:06:32 AM
Ordered Sheet List with Consultants Sheet
Tue, Sep 8, 2015 at 1:27:23 PM
Sheet numbers??
Wed, Feb 21, 2007 at 12:43:48 PM
Sheet
Fri, Apr 22, 2005 at 1:01:53 PM
Creating Sketch Sheets and linking revision tags to Original sheet...
Fri, Jul 14, 2017 at 11:16:32 AM
14
Page generation time: 0.3553
