59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> No lines around filled regions.
Tue, Jun 6, 2006 at 10:33:20 AM | No lines around filled regions.
Kalvin
I was wondering if I could make the outline of a filled region disappear...or at the least turn the outline white. Thank you.
Tue, Jun 6, 2006 at 10:57:11 AM | RE: No lines around filled regions.
krmccurdy
Select the filled region. Go to "EDIT". Select the lines that make up the boundary of the filled region and eitheir make them "<Invisible>" or some other linestyle that is white in the drop down menu.
Tue, Jun 6, 2006 at 10:58:52 AM | RE: No lines around filled regions.
Kalvin
Thank you!
Tue, Jun 13, 2006 at 11:54:14 PM | RE: No lines around filled regions.
ICON
5 Stars: 3 Votes
Wondering if this will export to .dwg as an invisible entity to compliment the "no pattern" option in the region properties or if it will show up in the .dwg. thank you
Tracing filled regions with linework
Tue, Mar 3, 2009 at 10:24:52 AM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation
Wed, May 25, 2005 at 1:35:38 PM
snap to filled regions in detail components
Tue, Jun 7, 2005 at 2:14:19 PM
Page generation time: 1.1702
