50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Room Tags -
Thu, Feb 14, 2019 at 8:03:15 AM | Room Tags -
kkhanolkar
Couple of issues
The rooms are on the same floor level. There is 150mm computational height of 180mm of the floor level
1. Some of the room - Nos 22, 23 & 24 in the WC are not showing up in the plan even though they can be seen in the section.
2. You can see in Image 2, that shape of the WC room tag is different and goes up the wall.
Cant figure out what it could be. Any advice to sort it out so that it shows up in plan and picks up the correct room height.
Thu, Feb 14, 2019 at 10:40:36 AM | Room Tags -
Read this HELP topic:
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-21560A99-86E5-4114-B4A5-DD2F57FFFBD7
Thu, Feb 14, 2019 at 2:10:51 PM | Room Tags -
kkhanolkar
Thanks for the link
I checked the upper and lower limits for the rooms. It was set to 2400 abv ffl. Howver as you can see from the 2nd image, the height of the room tag is less than 500mm.
so its still unresolved.
Thu, Feb 14, 2019 at 6:17:33 PM | Room Tags -
You say you checked out the limits for rooms....< That is plural.  There is a default setting that you can set and that is what you probably looked at.  BUT each room can have its own settings.  You may want to read the help again.
Fri, Feb 15, 2019 at 4:21:14 AM | Room Tags -
kkhanolkar
I had checked all the room individually to check the upper and lower limits. Hence I used the word rooms.
From the attached images 3, 4 & 5 you can see that even though the upper limit is set to for eg: 2339, the top grip is at 2339, the unbounded height is picked up at 2339 and the volume is 1.05 for a room of area 2.9sq.m. Which means the height of the room is 300mm. (When i know the room height is 2.5m)
Fri, Feb 15, 2019 at 6:22:12 AM | Room Tags -
Take a look again at your first image, room 00-24.  You can see to the right of that door the color blue of the selected room does extend up to what appears to be 2488.6 - not the ceiling.  The room on the left extends to this height as well.  Obviously someting in front of tghat room is hiding it.
Are you using some sort of wall for a toilet partition?
Fri, Feb 15, 2019 at 10:14:40 AM | Room Tags -
kkhanolkar
Its a standard metal stud wall with plasterboard on either sides. I can see the blue of the selected room does extend up to 2488.6 (Random height trials) But I dont know why its doing that. I cant find anything that could be causing the issue.
Thanks
Fri, Feb 15, 2019 at 1:21:36 PM | Room Tags -
The room is beyond your cut line! .... it is on the other side of that wall.  Check out your plan view.
Fri, Feb 15, 2019 at 1:47:26 PM | Room Tags -
kkhanolkar
I dont understand what you mean by ' your room is beyond your cut line. it is on the other side of the wall'
Fri, Feb 15, 2019 at 3:00:44 PM | Room Tags -
kkhanolkar
Found the answer... Fixed it
There was a rogue floor at 450 affl on a workset that was set to global not visible. Deleting that floor resolved the room tags..
Thanks for your help and quick responses.
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:59 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:49 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:13 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:52 PM
Vanishing room tags
Tue, Sep 6, 2005 at 5:54:22 PM
Page generation time: 0.4055
