64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Detail callout head size variable?
Wed, Feb 13, 2019 at 11:32:43 AM | Detail callout head size variable?
Sixto
Hello all,
I would like to have detail callout heads be able to be sized differently. However each detail seems to be tied to just one, meaning if I change the size of one, it changes the size of all the references to that detail.
See attached for a better explanation. I want to shrink the callout head circled in red to fit better, but when I do it shrinks ALL references to that detail. as shown in the second attachment.
How to I make it so detail callout head sizes are independent of eachother?
Wed, Mar 6, 2019 at 4:26:36 PM | Detail callout head size variable?
aandr001
4.5 Stars: 6 Votes
I am assuming that you did this by going into the family and resizing the circle because that is how I did it many years ago.  What you may not have done is save it as a new family with a different name, so that when you loaded it into your project, it just overode the same one thus making them all the same.  Do a "save as" with a slightly different name and see if that will work for you.
callout only head
Tue, Mar 26, 2013 at 7:09:21 AM
Rotate Callout Head?
Thu, Aug 1, 2019 at 10:08:03 AM
Callout head wont display
Wed, Sep 1, 2010 at 10:12:15 PM
Building Section and Detail Section Callouts
Mon, Aug 7, 2017 at 5:22:42 PM
Detail Callout Issue
Tue, Jan 25, 2011 at 12:57:37 PM
Page generation time: 0.7806
