41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit for UK 'Rights of Light' analysis
Tue, Feb 5, 2019 at 6:15:14 AM | Revit for UK 'Rights of Light' analysis
jamesm2505
Is there any way to use Revit for the British Rights of Light rules?
I've been trying to use insight lighting analysis for it but I'm not sure about the settings / interpretation required to get conclusive results.
The key points for these standards are
  • glazing / framing losses are not accounted for
  • a working plane is taken 700 mm above the floor level
  • areas with more and less than 0.2% 'sky factor' must be plotted for both with and without the proposed neighbouring building
  • over 50% of the room should have over this limit to avoid issues.
Is there any way to use Insight for this sort of output?
thanks
Analysis of a Light Gauge Revit Model
Wed, Oct 22, 2008 at 11:11:33 AM
revit structure
Mon, May 8, 2006 at 4:52:07 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:47 AM
Light fixture doesn't produce light
Sat, Jun 7, 2008 at 12:39:39 PM
2'x2' fluorescent fixture on rcp covers up part of adjacent 2'x2' return fixture
Fri, Aug 28, 2009 at 1:06:17 PM
Page generation time: 3.6436
