40 Users Online (39 Members):
Forums >> General Discussion >> Revit Project Management >> Instance Parameters Resetting
![clickster Avatar](user_avatar/417572.jpg)
I am working with a curtain panel family in Revit 2019. I have a few Instance parameters applied to the family, and I have set these to different values in the panels within my project. The problem I am having, is that when I make a change to the family and re-load it into the project, the instance parameter values change back to what they were when the family was initially placed... and I have to go through the project and set the Instance parameters again.
I have tried re-loading the family with "overwrite the existing version" option and "overwrite the existing version and parameter values", and I am getting the same result.
Has anyone else experienced this? Anybody know how to retain instance parameter values when families are reloaded?
Fill what is empty. Empty what is full. Scratch what itches. |
Overwrite existing version only should not do what you say. Look at this:
http://www.revitzone.com/family-creation/60-families-types-and-instances-an-overview
Add Yes/No Instance Parameters to Test |
Mon, Aug 12, 2013 at 3:43:59 PM
Instance Parameters [ 1 2 ] |
Wed, Aug 15, 2007 at 6:10:55 PM
16
INSTANT PARAMETER SCHEDULEABLE |
Wed, Jul 11, 2012 at 12:26:36 PM
Deleting Door Instance Parameters |
Fri, Oct 17, 2008 at 8:58:06 AM
Instance Parameters in titleblock not linking |
Wed, Dec 28, 2011 at 10:31:23 AM
12
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
