87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Annoying Warning When Opening Revit 9 files
Mon, Jun 5, 2006 at 7:35:23 PM | Annoying Warning When Opening Revit 9 files
JoshG
I have a user who says he gets an annoying warning when opening Revit 9 files. The message is "The total hard drive capacity in your system has decreased. This typically does not indicate a hardware failure. Contact your help desk if you did not personally change your system's hard drive configuration or disable devices in startup." I think he is getting this because the central Revit file was moved to a different server. Any ideas?
Tue, Jun 6, 2006 at 6:45:19 PM | RE: Annoying Warning When Opening Revit 9 files
JoshG
I found a resolution. The issue is not a Revit error but caused by Dell OMCI software. I uninstalled Dell OMCI software to fix the problem.
How to disble annoying Warning
Fri, Feb 9, 2007 at 7:09:03 PM
Faster opening of files
Fri, Dec 9, 2011 at 7:21:22 AM
Revit 2009 problem opening large files
Wed, Apr 23, 2008 at 9:36:38 PM
Revit 2012: Warning Error in a project "HELP"
Fri, Aug 15, 2014 at 11:14:03 AM
Revit shuts down without warning?
Tue, Jun 3, 2008 at 3:55:37 AM
Page generation time: 3.1741
