74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Model components correct in file but incorrect when inserted into building model
Sat, Jan 19, 2019 at 4:26:41 PM | Model components correct in file but incorrect when inserted into building model
ehoey
Hello,
Please see attached.  My window model components are in the appropriate positions in reference to the wall faces in it's file. However, when inserted into the building model, components are displaying incorrect.  My question is 2-fold; you'll see my latches that are on the exterior wall face are offset from the building & the concrete lintel (drawn as an extrusion) is appearing too far into the interior face of the building on my floor plan.  Any guidance is greatly appreciated!  Thanks.
Sun, Jan 20, 2019 at 2:26:23 PM | Model components correct in file but incorrect when inserted into building model
The view you show does not show us enough.  A plan, elevation and section may help.
The components you say are correct in the file (assume you mean family) may be locating off the wrong reference.  This has to be set up correctly in the family.
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:36 AM
Need Help With Links
Thu, Feb 17, 2011 at 4:54:09 PM
EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
Tue, Apr 29, 2008 at 7:54:06 AM
Creating my model from a linked Rhino file
Tue, Aug 4, 2009 at 12:00:06 AM
Stair Handrail Extension - Incorrect Height
Tue, Mar 14, 2017 at 3:41:28 PM
Page generation time: 3.2725
