70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> create a filter for floor surface patterns below
Thu, Nov 29, 2018 at 2:49:43 AM | create a filter for floor surface patterns below
bracha123
I would like to create a filter to apply to the view template for many plan views to allow me to turn off the floor surface pattern on all levels below.
I only see a way to create a filter choosing all levels below a specific level, and I want it to be below 'current' level.
Is there a way to do this?
Thanks
Fri, Nov 30, 2018 at 6:10:20 AM | create a filter for floor surface patterns below
tim123
4 Stars: 19 Votes
I don't think that you can do that.  I would suggest excluding V/G Filter overrides.  Then create a filter for each level and apply that to the views.  You might consider grouping your sheet View Category by level, and then apply the filter to those views.
Sun, Dec 2, 2018 at 3:45:02 AM | create a filter for floor surface patterns below
bracha123
Oh well. thanks, i did this. just takes longer than i would have liked.
Is it possible to create a filter that you can filter walls that have been demolished?  I don't see an option like that Sad
Thank a lot for your help.
Mon, Dec 3, 2018 at 12:04:36 AM | create a filter for floor surface patterns below
tim123
4 Stars: 19 Votes
Yes, you can do that.  For a schedule - see attached.
If you mean in the view, you can control it with the phase filters and graphic overides.
Mon, Dec 3, 2018 at 12:57:01 AM | create a filter for floor surface patterns below
bracha123
I would like this is the views.
I have demolished walls on many levels, and I use the view range in view depth to see everything below the level that I am on.  But the view depth just uses the line 'beyond' and wont show a demolished wall. The demolished wall appears also as a 'beyond' line.
I thought to use a filter to override that 'beyond' setting.
Any suggestions?
Thank you !
Mon, Dec 3, 2018 at 6:51:02 AM | create a filter for floor surface patterns below
tim123
4 Stars: 19 Votes
You will be able to set the levels below to their normal linestyles if you set the Bottom of the Primary Range to control the depth, rather than the view depth which will show lines as beyond for everything below the Bottom plane.
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:35 AM
Is there an easier way to create surface/fill paterns?
Fri, Dec 1, 2006 at 9:21:20 AM
Hiding Floor Surface Patterns in Revit 2008
Wed, Jun 13, 2007 at 1:14:17 AM
Floor surface pattern not "folding" - how?
Thu, Aug 29, 2013 at 7:41:07 AM
Revit fill/surface patterns for 2011
Tue, Oct 19, 2010 at 1:33:21 PM
Page generation time: 1.8482
