54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Railing on curved/sloped wall
Tue, Nov 13, 2018 at 3:00:05 PM | Railing on curved/sloped wall
johnfin
How can I add a railing on this wall. I tried a mass form which would work for a straight wall but this one slopes so I cant rotate the mass. Any ideas
Wed, Nov 14, 2018 at 1:27:08 AM | Railing on curved/sloped wall
tim123
4 Stars: 19 Votes
An option is to create a sloping floor or a ramp as a topping to the wall - a railing will host to these.
Wed, Nov 14, 2018 at 8:18:44 AM | Railing on curved/sloped wall
johnfin
I would like to be able to draw a massing form. I can extrude the railing but I cant seem to get the massing to follow the profile of the wall
Wed, Nov 14, 2018 at 3:57:02 PM | Railing on curved/sloped wall
Use a railing.
https://revitpure.com/blog/14-tips-to-understand-revit-railings
Thu, Nov 15, 2018 at 11:25:46 AM | Railing on curved/sloped wall
johnfin
That link is for straight walls. Revit cant put a railing ontop of a curved sloped wall, its not that smart.
Thu, Nov 15, 2018 at 3:38:27 PM | Railing on curved/sloped wall
Look again at the link.  #4 shows the railing hosted on a sloping wall.  You have to sketch the path of the railing.
Fri, Nov 16, 2018 at 12:02:11 PM | Railing on curved/sloped wall
johnfin
LOOK at the original posting title. CURVED.
Fri, Nov 16, 2018 at 3:41:38 PM | Railing on curved/sloped wall
CDWdavid
5 Stars: 5 Votes
I think it's doable.
See attached pictures.
Mon, Nov 19, 2018 at 12:05:07 AM | Railing on curved/sloped wall
tim123
4 Stars: 19 Votes
Did you try my suggestion?  Here is a curved sloped floor on top of a curved wall that is attached to the floor.  The railing hosts to the floor. The floor can be given the same finish as the wall.
Tue, Nov 20, 2018 at 7:18:04 AM | Railing on curved/sloped wall
johnfin
How did you draw the wall ontop of the curved wall(created from a mass).
Tue, Nov 20, 2018 at 7:57:15 AM | Railing on curved/sloped wall
#11
John,
Why did you create your wall from a mass?   It would be far better to use a wall and use a plane set at an angle to cut it.
Tue, Nov 20, 2018 at 3:55:42 PM | Railing on curved/sloped wall
#12
johnfin
I guess I dont know how to create a curved AND sloped wall that way. Super fast in mass, you and manipulate the grips of the form.
Tue, Nov 20, 2018 at 4:23:34 PM | Railing on curved/sloped wall
#13
Even faster using native tools.  Good place to learn something new.
Simple find / create an elevation or section that would be perpidicular to the plane you want the top of the wall to end at and read the following:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-ED60CE62-B955-45E9-9D7D-00F1552D858C
Wed, Nov 21, 2018 at 12:06:54 AM | Railing on curved/sloped wall
#14
tim123
4 Stars: 19 Votes
John
I drew a curved wall (normal wall - not a mass).
I drew a curved floor on top with a slope arrow.
I attached the wall to the floor.
I drew a curved railing over the floor.
I hosted the railing to the floor.
Curved railing.
Fri, Nov 15, 2019 at 11:36:40 AM
Sloped railing along a wall
Sat, Oct 27, 2012 at 6:59:22 AM
Creating a Curved Sloped Curtain Wall
Fri, Jul 9, 2010 at 2:20:04 AM
Sloped railing on sloped floor/ramp
Tue, Dec 9, 2008 at 9:25:01 PM
HELP! Curved Sloped wall with slanted top
Sat, Jul 26, 2008 at 9:16:30 PM
12
Page generation time: 1.4530
