42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Hole in surface
Mon, Nov 12, 2018 at 2:40:12 PM | Hole in surface
johnfin
How can I put a hole thru a surface. When I remove the cylinder the surface is still there. Not sure if this can be done in conspetual mass.
Mon, Nov 12, 2018 at 3:54:02 PM | Hole in surface
This shows how to cut with a solid http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-85920F8B-E67C-46D3-8296-000B06075843
but if you want to remove the solid, you need to use this instead. http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-7C940A08-1F62-465F-89BF-3800E3446FC3
Wed, Nov 14, 2018 at 11:53:09 AM | Hole in surface
johnfin
Cant get those methods to work on this item.
Wed, Nov 14, 2018 at 12:15:28 PM | Hole in surface
johnfin
I guess revit isnt smart enough to cut a varying surface. I tried it on a square like in the examples and it works.
How to infill a topo hole from plit surface
Fri, Jun 15, 2012 at 9:54:55 AM
Hole in my topo surface
Thu, Nov 8, 2012 at 8:36:27 AM
11
VOIDING TOPO FOR FNDN HOLE??
Wed, Jun 7, 2006 at 3:26:49 AM
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:59 PM
cutting a hole in a massed floor/roof
Mon, May 11, 2009 at 7:07:01 AM
Page generation time: 1.0001
