80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2019 - RPC not installing
Tue, Nov 6, 2018 at 4:08:52 AM | Revit 2019 - RPC not installing
Reddrev
Installed 2019.1
I have reinstalled REVIT 2019.1, but find the RPC content is not loading.   Little cubes/boxes appear in 3d views.  The tree plan is ok, but only a cube in 3d and no rendered images.
I have searched on the web and various suggestions refer to the family and to resaign the image etc.  But in the propertis window there are no 3d images.   Before resinstaling 2019.1, the previous 2019.1 installation was working fine.
I can open the sample archtectural file, this shows trees in 3d...  in the shaded view, but when switched to realistic, the trees and other RPC vanish.
If I open a tree family, there is a cube, if I select a visible 3d tree from the sample file and paste it into the family editor, it becomes a cube.
I am not sure where the rpc content folders are to see if the images etc ahve actually been installed, or if there is a problem with a plug in or some routine that calls up the rpc content.   All file directories are as the desfault instalation.
Many thanks.
Rpc Creator made Rpc can't load
Wed, Oct 24, 2012 at 5:12:33 PM
revit 2019 and revit 2024 same pc
Tue, Sep 19, 2023 at 7:54:32 AM
Revit 2009 - RPC's
Thu, Sep 9, 2010 at 3:16:35 PM
RPC and revit 2009
Mon, Jun 1, 2009 at 11:55:16 PM
Revit 2009 - RPC Archvision Content
Tue, Jan 6, 2009 at 10:46:30 AM
Page generation time: 1.5896
