72 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Schedule question
Dear BIM professionals;
Please advise the best way to filter out items in a schedule in Revit 2017.
Can't find a detailed filter tutorial.
Please see the attached image.
Thank you.
What are these items, that is important?
If you can group these items by adding a new shared parameter, that is the easiest way.
Thanks. I think this will work.
They are sheets, and i have the same problem with windows.
You always know the best way.
Sorry, what a parameter would you recommend to create?
Remember, using a shared parameter, you can always create a project parameter that is assigned to sheets.
You maight also consider using one of the existing parameters for this. The attached image shows a schedule using 'Comments' as the filter parameter.
Thank you! I think this "Comment" parameter will be the best solution. By the way, could you suggest a comprehensive Filter and Global parameter tutorials?
Room finish schedule question |
Wed, Jul 8, 2009 at 3:33:52 PM
Schedule Question |
Fri, Oct 24, 2008 at 1:24:24 PM
Quick Wall Schedule Question? |
Tue, Oct 21, 2008 at 12:40:21 PM
Door schedule question |
Thu, Sep 17, 2009 at 2:42:30 PM
Schedule question |
Wed, Jan 7, 2015 at 8:37:40 AM
Members: | 2016987 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
