Forums >> Revit Building >> Technical Support >> Fill Pattern
25 Posts No Rating |
Hi All,
I am trying to import a fill pattern, Cultured Stone Carolina Ledgestone 184, and when I do the pattern is nothing more than solid black.
I downloaded the pattern from the Fill Patterns portion of RevitCity.
DJ
you will need to change the scale under surface pattern materials-model. i think 24 is the scale that works for those patterns.
I can't seem to figure out how to change the scale. All references to scale are grayed out and can not be edited.
Click on surface properties icon
click on new, custom, import,
find your hatch pattern load it in, then click on the imported file name next to "import" (in the white block),
you can then change your scale
Hope that helps
Will
Thanks all, that did it. Not too intuitive on Revit's part to explain in its help files how to do.
color scheme/fill pattern |
Mon, Jul 9, 2012 at 4:56:37 AM
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:25 PM
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:02 PM
Fill Pattern not show up when print |
Wed, Apr 25, 2012 at 4:08:56 AM
Lost Solid Fill Pattern |
Wed, Apr 9, 2008 at 7:58:48 AM
Members: | 2101055 | Objects: | 23173 | Forum Posts: | 152299 | Job Listings: | 3 |
