50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> moving view to different sheets?
Is there another way to move views to different sheets than to first delete them and then drag them back onto another sheet.
Got six views, to economize I want to transfer them to a different sheet, but it almost feels like I need to right the names down so I didn't forget which views were deleted from the incorrect sheet.
Just expand your sheet browser and click on the views and drag them to the sheet which you have open.
----------------------------------- VND |
33 Posts No Rating |
There's no good way to move them from one sheet to another. But something that may help you keep track of what you've deleted is to change your project browser to reflect views not on sheets. I can't remember now if this is a standard out of the box feature or not.
Click on the eyeball at the top of the project browser window. Should say "Views - Architectural" or "Views" or something next to the eyeball. If you click on it once, you can use the drop down menu to get other project browser views. I have one called "View (not on sheets)". If you don't have something like this in the drop down menu, go to the properties of one view, edit, and duplicate. After you've named the new browser type, go into "Filters" and set the three fields as follows "Sheet Name", "Equal To", "None". Now in the project browser, only those views not on a sheet will be shown. After you moved things around, you can change back to the old project browser view by selecting it from the drop down menu after you select the eyeball again.
you can copy to clipboard the views that you want to transfer, immediately delete those views.
then open the sheet you want them on and paste from clipboard.
works great.
What version are you using?
I'm in 8.1 and can't get the views to copy to clipboard. I get a warning about duplication of views not being supported when I attempt to copy to clipboard.
When I copy the viewport to the clipboard, I don't get any options to paste when I get to the other sheet.
I've never tried this in 8.1.
I immediately delete the views after copying them to the clipboard, before I paste them to another sheet.
I'd think that would eliminate the "duplicate view" warning in 8.1, but I don't know
Moving views onto different sheets |
Fri, Sep 12, 2014 at 10:10:29 AM
Same View on Multiple Sheets |
Sun, Aug 28, 2005 at 5:51:36 PM
Moving View Title |
Sat, Mar 6, 2004 at 9:46:28 AM
Formulas for View Names |
Mon, Aug 29, 2011 at 3:45:43 PM
Aligning Dependent View across Sheets |
Wed, May 7, 2008 at 11:41:51 AM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
