96 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to create roads on terrain?
Wed, Sep 26, 2018 at 11:59:05 PM | How to create roads on terrain?
gale6481
How to build roads on the terrain? I use building pad but it has error: two pad with different slope not match with each other. Is there any better way to help me? Thanks all.
Không có văn bản thay thế tự động nào.
Thu, Sep 27, 2018 at 1:01:14 AM | How to create roads on terrain?
tim123
4 Stars: 19 Votes
It depends what you need to achieve.  If it's for visual purposes, you could use a subregion, or you could split the surface to show the different levels.  Revit has never been very good for civil works, so you will have limited functionality with these options.  Another option to consider is using the railing tool to create the road, as this can follow the contours of the topography.  There are also add-in apps that you can use, such as Siteworks.
Thu, Sep 27, 2018 at 11:30:56 AM | How to create roads on terrain?
Here is the best method that was posted several years ago.  This one creates a road with curbs but you could do this in a similar manner if you had ditches instead.
revit terrain and roads
Wed, Jul 25, 2012 at 2:19:58 AM
Roads in a slope
Fri, Jan 13, 2012 at 1:47:52 PM
Where are the roads?
Thu, Jul 17, 2008 at 2:13:40 PM
Roads
Mon, Apr 3, 2006 at 10:21:48 AM
How to make Roads in site?
Mon, May 31, 2010 at 4:29:42 AM
Page generation time: 1.7052
