63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Hide windows and openings
Wed, Sep 26, 2018 at 4:01:46 AM | Hide windows and openings
koleman
Hi all,
i would like to turn off all the windows in my project just to shaw a raw volume.
Is it possible to hide the wall openings as well?
Thank you in advance!
ps. I´m using revit 2019
Wed, Sep 26, 2018 at 1:08:41 PM | Hide windows and openings
In VG, you can turn off the windows and doors but openings are openings!  There is no wall in an opening.
Wed, Sep 26, 2018 at 2:38:05 PM | Hide windows and openings
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You can set your cut plane to be above the windows, or below if you don't mind to see doors.
Thu, Sep 27, 2018 at 10:02:19 AM | WWHub
koleman
Quoting WWHub from 2018-09-26 13:08:40
so ther is no way to turn off openings? I´ve tryed adding a visibility parameter to the void in the windows family but it´s not possible.
I guess workaround is to copy the project and erase all the windows.
How to hide/trim mullion corner edges
Wed, Oct 26, 2011 at 7:32:26 AM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:12 AM
Copy/Monitor Openings
Tue, Aug 9, 2016 at 3:41:47 PM
Exclude wall openings and windows etc from wall schedule
Tue, Nov 12, 2013 at 4:46:25 AM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:29 PM
Page generation time: 0.6929
