80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> resizing camera views??
Sun, Jun 4, 2006 at 11:31:37 AM | resizing camera views??
ICON
5 Stars: 3 Votes
I have some camera views placed on a sheet. Trying to change the size or scale if you will, like you would do through the properties dialogue box for floor plan view. Didn't see on option in there to change the physical size of the view. Seems like the only modification choice I have is to select the viewport and move the grips. Problem is, that only adjusts the cropped view, resulting in less information almost as if you were zooming in on, for instance, a doorknob or whatever. It doesn't change the "scale" of the image, it only give you a smaller "aperture" so to speak, to see with. Any suggestions?? Thank you in advance. Randy
Sun, Jun 4, 2006 at 12:17:28 PM | RE: resizing camera views??
TomDorner
4.5 Stars: 25 Votes
In the camera view, click on the extents window (outer frame) and in the options bar above select "size". In the "size" dialog you can change the size of the view with locked proportions. Also, be sure to explore the use of the F8 key when in camera views. It brings up a special window to change the view dynamically using commands like, zoom, dolly, pan and twist which are the equivilant to moving a camera based on film techniques. Tom
Sun, Jun 4, 2006 at 12:24:46 PM | RE: resizing camera views??
ICON
5 Stars: 3 Votes
Thanks, This learnin' curve is wearing me out. At what point does a person atleast feel like he's got a grasp of the range of Revit features and general work around.
Sun, Jun 4, 2006 at 12:29:47 PM | RE: resizing camera views??
TomDorner
4.5 Stars: 25 Votes
For me the learning curve started to flatten after two years. Of course I attended AU three times by then which really does boost your Revit knowledge. I now have three years of Revit under my belt and things are less of a mystery. You just have to keep plugging along reading and learning all you can. Tom
Camera views export blank images
Mon, Dec 9, 2013 at 2:13:16 PM
Printing Camera Views Light
Tue, Nov 1, 2011 at 8:16:08 AM
TAGGING CAMERA VIEWS
Fri, Jul 23, 2010 at 7:34:18 AM
Camera Views In Plan (TARGET ADJUSTMENT)
Sat, Oct 30, 2010 at 8:16:47 AM
Exporting Revit Model with Specific Camera Views
Tue, Jun 4, 2013 at 1:51:54 PM
Page generation time: 0.7458
