71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> structural framing family cut pattern interacting with wall in section 2017
Tue, Sep 4, 2018 at 1:33:50 PM | structural framing family cut pattern interacting with wall in section 2017
ledgewood33
i have all my structural framing family material cut pattern the same (dark gray). my wall patterns are set to a light gray. when the two interact the wall seems to take precedence. how do i get the structural framing family to be the dominate item in the section? attached are PDF's of examples for the above
158341_structural_framing_cut_pattern_1.PNG158341_structural_framing_cut_pattern_2.PNG
Tue, Sep 4, 2018 at 2:49:25 PM | structural framing family cut pattern interacting with wall in section 2017
Did you try to join these objects?
Tue, Sep 4, 2018 at 3:00:11 PM | structural framing family cut pattern interacting with wall in section 2017
ledgewood33
join tool doesnt seem to work with structural framing families
Wed, Sep 5, 2018 at 12:52:57 AM | structural framing family cut pattern interacting with wall in section 2017
online2000
online2000 Avatar
hi
option 1
try using chnage join order
option 2 - i assume that you made the cut line wieght smaller than the strctural framing cut line
eli
cut pattern in section
Wed, Jun 1, 2011 at 4:31:00 AM
DIFFERENT LINE THICKNESSES FOR STRUCTURAL FRAMING ELEMENTS IN SECTION
Tue, Sep 28, 2010 at 7:16:15 AM
Wall Cut Pattern Plan View vs. Section
Fri, Jan 6, 2012 at 11:19:22 AM
What should the Revit Structure Cut Plane Depth be set to on framing sheets?
Mon, Nov 21, 2011 at 1:44:29 PM
Earth and Wall cut patterns not showing in wall section...
Thu, Jan 5, 2012 at 3:08:37 PM
Page generation time: 2.0334
