26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> ceiling tag to read as spot elevation (top or bottom elevation) (2017)
Tue, Aug 28, 2018 at 10:34:45 AM | ceiling tag to read as spot elevation (top or bottom elevation) (2017)
ledgewood33
i would like to have a ceiling tag read the way a spot elevation reads the "top elevation" or "bottom elevation" of an element? for instance, in an RCP i would like the ceiling tag to read the underside of the ceiling (gyp.bd.) or "top elevation"
Tue, Aug 28, 2018 at 10:51:11 AM | ceiling tag to read as spot elevation (top or bottom elevation) (2017)
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I have never been able to do this but I understand using Dynamo it can be done.Do a search in Revitcity for ceiling tag ceiling height - there are a few results.My work-around is to select the room and set the Limit Offset parameter to the correct ceiling height.  Then I create a ceiling tag and change the category to room, add in the "Limit Offset, then change it back to Ceiling Tags and add finish or type parameters.
Spot dimension tags and thier relationship to ceilings
Wed, Feb 23, 2005 at 5:29:13 PM
Spot dimensions for Bottom of Ceiling elevation, not top of ceiling frame
Tue, Jun 13, 2006 at 11:14:41 AM
Floor tag - elevation spot
Thu, Apr 27, 2017 at 7:20:10 AM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:28 AM
Spot Elevation tag
Tue, May 6, 2014 at 12:41:10 PM
Page generation time: 1.9459
