59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Door mods
Thu, Aug 23, 2018 at 3:57:15 PM | Revit Door mods
johnfin
I have been trying to modify the jamb thickness of these HM steel doors. I was custom jambs that are 6" wider on each side, kind like side lights. Tried to edit the extrusion, no luck. Cont figure out how to change the paramaters.  Here is a link to the doors:
https://www.steeldoor.org/drawings.php
Mon, Aug 27, 2018 at 9:57:48 AM | Revit Door mods
tim123
4 Stars: 19 Votes
Can you be a bit more specific as to which doors you are referring to?  Your link leads to multiple doors.
Mon, Aug 27, 2018 at 10:36:15 AM | Revit Door mods
I believe the typical Revit door jamb is a profile sweep,  As such, you would have to edit the profile family to put an option there and then control that in the door family.  But then there is the head.....should it be the same as the jamb?
Mon, Aug 27, 2018 at 12:16:33 PM | Revit Door mods
johnfin
On that sire, steel pair, no glazing. I tried to change the profile, no luck. There is a ref plain or hidden formula that controls the jambs.
Mon, Aug 27, 2018 at 2:24:09 PM | Revit Door mods
In the door family, the door opening, which now has to be larger, is controlled by the opening cut and that is sized in the family.
DOOR TAG QUESTION
Fri, Mar 1, 2013 at 7:32:20 AM
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:47 AM
Door Schedule
Fri, Aug 17, 2012 at 7:07:51 AM
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:51 PM
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:26 PM
Page generation time: 3.9057
