24 Users Online (22 Members):
Forums >> Revit Structure >> Technical Support >> Bottom of Pipe Elevation
Revit 2017 - I have a site plan and I want to do a spot elevation to the bottom of the pipe. It keeps snapping to the top of pipe. Is there a way to snap to the bottom of the pipe or am I missing siomething. I have attached a PDF of what I am talking about. The b.o.p should read 12'-9 3/4" which it is at 12'-9 3/4"
I got it - Thanks Byron
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
This site works because of good questions and answers. If you answered your own question, we ask you to post the answer for others to see.
It was really simple when I calmed down and looked slowly.
Place Spot elevation, Select the tag and look in properties under text you havfe a slection for top, bottom elevations
pipe dimensions |
Wed, Dec 2, 2015 at 7:47:03 AM
Spot elevation Tag and Insulation |
Wed, Jun 11, 2014 at 10:00:27 AM
Centerline elevation of pipe below underside of floor above |
Mon, Dec 22, 2014 at 8:11:21 AM
Issues with Pipe elevation tagging |
Mon, Aug 24, 2015 at 8:23:31 AM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
Members: | 2025982 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
