23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> cHANGE DIMENSION TEXT
Thu, Aug 2, 2018 at 10:47:44 AM | cHANGE DIMENSION TEXT
1bchristian
revit 2017 - Is there a way change the dimension value in dimensions.For example The dimension is 30' I would like to type in 23'. Thanks Byron
Thu, Aug 2, 2018 at 1:49:44 PM | cHANGE DIMENSION TEXT
This has long been discussed on the forums an almost evry good Revit user will tell you that this is a bad idea.  Revit works very well because you can trust it.  Pulling CAD tricks like dimension mover-writes is just poor practice.   Edit your Revit model instead.
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Dimension Text Overide
Wed, Jun 27, 2007 at 7:13:42 PM
Why I cant change Dimension fonts?
Thu, Aug 10, 2017 at 11:51:39 AM
Detail Custom Text Change
Thu, Oct 23, 2008 at 11:59:06 AM
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Page generation time: 1.2279
