80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Funny Barn Door
Fri, Jul 27, 2018 at 10:57:17 AM | Funny Barn Door
1bchristian
Revit 2017 - I have a barn door attached. I need to keep every thing as is but have the rough opening to be double the size of the door. That way as the doors moves 50% of the rough opening is always closed. Anyone know if this can be changed and how. - Thanks Byron
Mon, Jul 30, 2018 at 7:06:45 AM | Funny Barn Door
tim123
4 Stars: 19 Votes
Select the opening and modify it.
Mon, Jul 30, 2018 at 8:04:08 AM | Funny Barn Door
1bchristian
I have tried that Please explain - Thank you Byron
Tue, Jul 31, 2018 at 7:32:33 AM | Funny Barn Door
tim123
4 Stars: 19 Votes
Tab through to pick the opening, not the wall.
However, look at your parameters - you are forcing the door to be the same width as the opening.  Use the default opening - this is a family parameter, which has already been set into the template.  Control the width of the door panels based on this - eg door panel width is 1/4 of the total (opening) width.
Wed, Aug 8, 2018 at 11:15:38 AM | Funny Barn Door
1bchristian
Got it - Thanks Byron
Hinged barn door
Thu, Oct 22, 2020 at 9:44:19 AM
Phase to old barn
Thu, Oct 29, 2009 at 6:54:16 AM
Has anyone seen or has a Barn Light rfa file?
Mon, Jul 13, 2015 at 3:55:17 PM
Automatic dimensions to door family defaulting to wrong side of door.
Fri, Jul 22, 2016 at 9:58:34 AM
Why isnt the Range Top, knobs and door handle not showing up in my Rendering
Thu, Dec 4, 2014 at 12:30:51 PM
Page generation time: 1.1364
