70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> spoiled ctrl TAB no longer works
Wed, Jul 25, 2018 at 1:25:01 PM | spoiled ctrl TAB no longer works
sllana
5 Stars: 2 Votes
Hi, I have noticed that the control-tab, in Revit 2019, no longer returns you to the LAST window you were. It loses the secuence at all. Or am I missing something, any tip about it?
Thu, Jul 26, 2018 at 2:17:09 PM | spoiled ctrl TAB no longer works
Uncreatedbody
I beleive this is a new feature in Revit 2019. If you have multiple views open, the tabs are positioned just below your ribbon. Control+Tab cycles to the right, Shift+Control+Tab cycles to the left.
Fri, Jul 27, 2018 at 9:55:06 AM | spoiled ctrl TAB no longer works
sllana
5 Stars: 2 Votes
Yeah, it seems so. Make no sense to have the tabs order in one hand and "ctrl-tab" doing the same in the other, instead of taking you cycling back your way. It is stupid.Edited on: Fri, Jul 27, 2018 at 10:09:41 AM
Edited on: Fri, Jul 27, 2018 at 2:57:17 PM
Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit?
Thu, Jun 26, 2014 at 2:51:36 PM
View Previous
Fri, Nov 13, 2009 at 12:21:47 PM
Revit crashes whenever I hit CTRL + Tilde key
Tue, Dec 7, 2010 at 7:19:37 PM
using contol or option keys when setting hot keys?
Mon, May 18, 2009 at 4:47:27 AM
PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
Mon, Mar 28, 2016 at 11:32:05 AM
11
Page generation time: 0.4667
