45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall void
Tue, Jul 24, 2018 at 3:48:16 PM | Wall void
johnfin
I have a cavity wall made up of components and I need to remove a portion of the brick veneer above a window. Dont think I can use an opening because it would be the full wall thickness and I tried a void sweep but it only works on a 3dsolid. Any thoughts?
Edited on: Tue, Jul 24, 2018 at 3:54:11 PM
Tue, Jul 24, 2018 at 5:47:36 PM | Wall void
You can use a wall sweep - void- where you pull the ends back to where you need.
You can also create a face based family - void- that cuts it's host.  That could be parametric so you could use it for multiple applications.
Wed, Jul 25, 2018 at 8:46:28 AM | Wall void
johnfin
I tried the sweep void on a wall and it would not voild, only on 3d solids which a wall is not. How do I do the face based family?
Wed, Jul 25, 2018 at 9:02:49 AM | Wall void
The wall sweep void works so something is wrong with your process.  Remembe - this is a wall swepp, not just a sweep.
There is a face based template in your template file.   The shape has to be within the face, not sitting on it.
Wed, Jul 25, 2018 at 10:37:11 AM | Wall void
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
This is a new wall type. Create the new wall type. ( same as cavity wall without brick veneer). Go to already modelled cavity wall and edit the profile in elevation and cutout that part of the wall that needs to be a new wall type. The model in you new wall type into the cutout void you created. Align the internal face and join the two walls to remove any seams.
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:24 PM
Wall Hosted Family cutting void into Wall
Mon, Aug 23, 2010 at 3:59:00 PM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:07 PM
Void forms
Tue, Sep 6, 2011 at 5:53:34 PM
12
Cutting wall end with in-place void - Revit 2018
Thu, Jul 6, 2017 at 5:08:31 PM
Page generation time: 2.9957
