27 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> Create a moulding I think.
Revit 2017 - Does anyone know and can tell me how to approch create something like the attached in revit. - Thanks Byron
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
What are you using it for first?
Revit 2017 - I am using it on the attached furniture. - Thanks Byron
Got to front elevation, create tab, Forms section, Extrusion, Trace perimeter & holes of shape, click green tick icon in ribbon to finish, go to plan and click the extrusion you created and adjust its length to suit whatever width it is. Repeat the above for the inner webs. In plan select both shapes, rotate and move to correct orientation. Copy as required.
Beatiful worked like a champ - Thanks for the instructions. Byron
Revit 2017 - I hit another stump, How to rotate something about the x axis to have it stand up. I have attached the file agian and you can see that the cross is laying down. I need to stand it up and attach to the center door.
You have to go to the elevation view that is correct for the rotation orientation. It won't let you do it in a 3D view. Sometimes in models objects still won't rotate as they are associated with a certain plane. To disassociate that relationship, you copy the object and paste it and then rotate the duplicate object.
Adding quarter round moulding to existing base board moulding |
Tue, Nov 20, 2007 at 8:43:48 PM
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
baseboard moulding |
Fri, Jan 27, 2017 at 10:40:33 AM
Help with a single stone moulding window |
Thu, Aug 18, 2005 at 3:31:42 AM
Crown Moulding Return |
Thu, Aug 22, 2013 at 2:52:28 PM
Members: | 2025990 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
